need a little info
i wanna wire a kill switch to my starter signal wire now i need to know what color that wire should be and if this would be a good enough way to keep the car from starting unless its flipped? i've searched and havent found exactly what im looking for... i need to know the wire color and where it runs from to the fuse block. thanks guys.
Not sure off the top of my head, and my friend has my Haynes manual.
I think mine was yellow/green but thats for a 96-00 Civic. Possibly different for your chassis.
or...... use the clutch switch..... the engine won't turn over if you use that
as for a switch... i would try and find something to put into one of your empty factory switch holes ( by using a factory switch) that way if someone trys to steal it they wont know which switch to push or how to actually crank it.
imo
yeah i wanna rewire my fuel pump one into the rear defroster switch? since it doesnt work anyway...
