Need a muffler
Discussion in 'Civic - EP, FA, FG' started by haao13, Sep 5, 2011.
  1. haao13
    haao13 New Member
    PA
    My stock exhaust is beginning to leak at the flex pipe so what a better reason to go aftermarket. A local exhaust shop custom bends stainless exhausts for cheap but ill need a muffler so id like some opinions. I want one that looks semi stock but with a little "growl" in the higher r's. I really like the ws2 but is out of my price range. Its for an 07 ex if it helps or matters
  2. haao13
    haao13 New Member
    PA
    know if they have it for an fg civic?
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Probably not but you can look into it. But I would guess that the replica exhausts are not on the fore front with such a new car.
    If you only need a muffler (hope this shop you wrote of does mandrel bends) then Ebay will work. Vibrant makes a black sleeper muffler and I bought one. It has been known to be quiet for a straight threw design but, if there is even a slight chance of getting pulled over for exhaust, I also strongly suggest you buy a resonator (goes after cat) to quiet things down.
    Should be able to get a muffler and resonator for less then $230 shipped. Any cut corners will most likely result in some crappy sounding exhaust that you are not happy with.
    Best option (in my opinion) is the WS2 you wrote about. Save up......make it happen b/c its a pretty big part of your driving experience and looks.
  4. haao13
    haao13 New Member
    PA
    Checked last night and unfortunately they dont. Yes they do mandrel bend. I called for a quote the other day and he said it would around 200 without a muffler for 2.25 stainless. I really like the vibrant but the videos I watched on youtube seemed pretty loud. If i cant find anything ill probably go with it. Id love to get the ws2 but unfortunately thats not an option. With student loans coming into the picture very shortly, next month :(, its just too far out of my budget.
  5. eg6sir
    dynomax turbo muffler w/ a resonator .. not gonna get any quieter unless its OEM
  6. haao13
    haao13 New Member
    PA
    i dont want it really quiet, just not obnoxiously loud like my old civic
  7. TurboMirage
    you could just replace the flex pipe? seems like the best option to me.
  8. haao13
    haao13 New Member
    PA
    I could but the derelict that had the car before me did some hack job shady mechanic job on the entire exhaust which is another reason id like new. He literally cut the cat out and just welded in a piece of pipe. Back towards the muffler it looks like he welded whatever pipe he had laying around and its not even the same size piping. If I can find a way to get an underneath picture ill post one this beauty of a job
  9. TurboMirage
  10. BrutalB83
    Rochester Hills, MI
  11. haao13
    haao13 New Member
    PA
    My apologies
    Indeed. If it werent for student loans I would probably get the vibrant system. Unfortunately thats not the case so im going to have a local shop do the tubing and get a muffler. Im leaning toward the vibrant streetpower but has any anybody had one or heard anything about them?
  12. eg6sir
    you'll like the dynomax .. check it out
  13. Matts96HB
    Matts96HB . Moderator VIP
    x2 on the dynomax. best bang for the buck
  14. haao13
    haao13 New Member
    PA
    i dont mind the dynomax. i really want one with inlet/outlet centered. any opinions on flowmasters? i saw a few vids of civics with 40 series and they sound pretty decent
  15. Fernpatch
    Fernpatch Member
    Bellingham,WA
    I put a flowmaster on my brothers 91 si about a month ago. It ended up being quieter in the cabin than the burnt out stocker it replaced. Nice and quite under light throttle with a hint of burble. Has a good grumble when you wind it up to higher rpms. If done right a flowmaster can be a good option. Also check out magnaflow. I liked the way my old crx sounded with a magnaflow resonator and muffler. Vibrant makes some good sounding units as well.
  16. eg6sir
    if you go w/ Magnaflow be sure to run a resonator..
  17. haao13
    haao13 New Member
    PA
  18. eg6sir
    vibrant makes good products..
  19. haao13
    haao13 New Member
    PA
    you know what series?
  20. TurboMirage
    anything but a 44 is good :lol:
