Need advice on engine swap into 98 civic dx.
Discussion in 'Engine Building' started by OkO, Jul 14, 2010.
  1. OkO
    OkO New Member
    Hi.
    Recently, I started thinking about doing an engine swap on an 1998 civic dx, and quite frankly, I know almost nothing about doing an engine swap. Could you give me advice on what engine would fit, an estimate on how much everything would cost, etc.?
    Thanks in advance ;)
  2. 99sidude
    Ohio
    Welcome to Hondaswap! This is a very common question that we get quite often. I would start by reading up in here: Technical Articles and Reference - HondaSwap Forums. Anything referring to the "EG (92-95)" and "EK (96-00)" chassis will usually pertain to you.
    An engine swap will cost you anywhere from $500 - 10,000 depending on what you goals are and whether or not you do the work yourself. First identify what you want out of the car and go from there.
  3. OkO
    OkO New Member
    Thanks!
  4. BrutalB83
    Rochester Hills, MI
    Anything B-series or D-series will be a bolt-in swap for you. H-series, K-series, and the J-series V6 engines will work also, but those are not exactly bolt-in...
  5. dateg513
    dateg513 New Member
    cincinnati
    you do a civic type r for under 4g's
  6. BrutalB83
    Rochester Hills, MI
    I doubt that, unless you're buying from some shady dude on Craigslist and the motor's ID is scratched off...
  7. E_SolSi
  8. egb19c
    egb19c New Member
    ... and CTR engines are over-rated, no torque sucks :(
