Need Answers Please
Discussion in 'ECU's, Electronics, and Tuning' started by udcivic, Jun 21, 2008.
  1. udcivic
    udcivic SiR-G
    Janesville WI
    ok i put a jdm b18c into the my 99 civic ex, when i take off i kinda hear my vtec kick in but it doesn't sound or feel like it should. Is this right or do i have a problem? Oh and i have been told on jdm engines you dont need the vtec oil pressure switch in order for the vtec to work. Is this true? cause i tested my switch and it has no 12v going to it ....even at the ecu. which is also a jdm p72.
  2. efhondakid
    Akron-Canton, Ohio
    How is vtec going to work with no power going to it? Not by magic, you need to wire that up fo it to work. And as far as the noise, that could be a million different things.
  3. 801CRX
    801CRX Got Rice?
    UTAH
    ^^ Yeah and Vtec does not kick in right when you take off.
    You need to wire up a RPM sensitive switch to activate Vtec. That sound you feel and hear might be your intake.
  4. udcivic
    udcivic SiR-G
    Janesville WI
    vtec solenoid has power to it and it kicks in...i was just asking since it wasn't that loud would there be a chance of it not engaging fully? I also know vtec don't kick in when you take off .....i meant when i punch it.
  5. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    What rpm do you hear or feel your VTEC kick in?
  6. udcivic
    udcivic SiR-G
    Janesville WI
    4500-4800 rpm which is where its suppose to kick in.
  7. Luis998
    Orlando, Florida
    I really don't think you have a problem then my friend. If you hear it, you should be fine. From what I have learned, some tuned cars after they have been upgraded don't really have a VTEC "sound" to them if you will, but it's still there. ^_^
  8. udcivic
    udcivic SiR-G
    Janesville WI
    thats what i was thinking but i just wanted to make sure. thanks
