Need answers please!!
Discussion in 'HYBRID -> EG-EK / DC' started by DustinEG6, Sep 12, 2006.
  1. DustinEG6
    DustinEG6 Junior Member
    I have a 93 Si with an LS swap in it. I swapped the LS myself and it runs great, I am running the 94 ls ecu. I am about to swap a 98 OBD2A GSR and just need my wiring ?'s answered.
    1. Beings my car had a Z6 in it I am still wired for vtec right?
    2. What sensors do I need to wire?
    3. I have the OBD2A ecu get conversion right?
    any diagrams would help out tremendously I know this has probably been asked a million times and I thank anyone for the help offered.
  2. TurboMirage
    yes
    none if you get an obd2a-obd1 conversion harness
    run a chipped p28 or p70? obd1 gsr ecu.
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    1) Correct.
    2) IABs
    3) Find an obd1 p72, or a chipped p28 and use a p72 chip in it.
    There's a wiring diagram in the reference section of HondaSwap showing exactly what to do.
    Don't use the obd2a gsr ecu, the harness from the LS will plug right in, but you'll have to add wires for VTEC/IABS.
    If you have z6 wiring harness, use that instead.
    If you run the obd2a ecu, you're going to have to run knock sensor, and crankshaft positioning sensor wires also.
