Need b16a Help
Discussion in 'Civic and del Sol - EG and EK' started by Graves, May 6, 2008.
  1. Graves
    Graves New Member
    Ok so i noticed the other day that my B16a (94 vic) will no longer rev past 4G. It cuts off fuel at that point. I took it to the shop and they told me to get a new distributor. So i did and it didn't fix anything. I took it back and they told me since I have an automatic computer in my 5 speed none of the codes are reliable and that they couldn't help me (this is a Honda dealership we are talking about here). Instead they told me I was getting 04-1 Crank position sensor no signal and 19-2 auto lock up failure "may continue to see problems unless ecu is replaced with a 5 speed." I've noticed that one of the wires running to a green plug ( I think is the Vtec Solenoid to the right of the dizzy on the left hand side of the engine) is gone. Any ideas on what the problem could be?
  2. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Get a p28 from a manual transaxle obd1 civic.
  3. Graves
    Graves New Member
    wire is labelled "vtec Pressure" (the one that is snapped).
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Find out what's wrong with the Crank position sensor using the flow chart in the Helms manual.
    Also, my D15B did the same thing. Turned out the ECU took a crap(replaced it and everything works again)..
  5. Graves
    Graves New Member
    I called honda back today and they told me I needed a new computer. They said the signal wasn't being sent to the sensor. so i'm looking into buying a chipped p28 now.
    thanks
  6. Graves
    Graves New Member
    would it make more sense that my sensor is bad or that the computer is bad if there is no signal?? Is there anyway to check if its my computer?
  7. K2e2vin
    Raleigh, NC
    Swap in another ECU. That's how I found out my P28 was bad. I put in a P05(Civic CX) and PT3(Accord LX) ECU; both that do not have VTEC and aren't for the engine yet revved over 4000rpms fine and ran better than the P28 that was in limp mode.
  8. LS_VTEC
    NJ
    DOH ;x
  9. Graves
    Graves New Member
    Will do Thanks
