need build tips for b20b
Discussion in 'Integra' started by Novishok, May 2, 2018.
  1. Novishok
    Novishok New Member
    puerto rico
    hey guys i'm new to the Honda scene i actually came from rotaries but i want to try something different. so i bought a 1990 Acura integra ls sedan and swapped in a b20b with 440 transmission and type r differencial. my question is do you guys have any tips on what to do to the engine? i'm going NA budget is 4k for now
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    A popular and solid build would be:
    Aftermarket 12.5:1 pistons and rods (or higher compression).
    VTEC Bseries head with port work/valves/springs/retainers
    VTEC conversion kit for the non-VTEC bottom end
    Aftermarket intake manifold to compliment head work
    Decent sized throttle body matched to intake manifold
    Header to compliment head work
    Camshafts to compliment head work and pistons (valve to piston clearance, rpm desired range for powerband, other things I don't understand yet, etc).
    Big injectors (1000cc+)
    Fuel pump
    Some sort of fuel line modification that can vary
    Fuel pressure regulator
    ECU prepped for tuning.
    Ethanol fuel for moderate hp gains (over pump 93)
    Something more nasty like VP M5 for bigger gains but it's kinda volitile
    Other stuff I'm forgetting
    Get a tune from your best option in your relative local area
    Companies? Brands? I have my preferences.
    Matts96HB likes this.
  3. Novishok
    Novishok New Member
    puerto rico
    this is my first Honda ever, but i was planning to get skunk 2 intake manifold, skunk 2 exhaust, hondata s300, aftermarket headers etc. i"='m just testing the waves to see if i like it or not i got the car dirt cheap for what it was.
  4. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    4k to drop ? spend 1500 on a basic quality parts turbo kit on like 8-10 psi and make 350whp and call it a day and be reliable and spend the rest on jdm tyte dood mods and wheels and coilovers and buy a front lip and ITR spoiler and a dope cf hood and still have cash to spend
  5. dilbeckskate
    Kennesaw Ga
    oh yea Welcome To HondaSwap ! post pics
  6. CAFROG
    NOR-CAL
    If you are not doing motor work....don't get a aftermarket intake mainfold. Its a waste.
    Intake piping and filter? Yes.
    Header is a good choice.
    Exhaust is a good choice.
    That's only about $800-1500 roughly.
    Staying non-VTEC?
  7. CAFROG
    NOR-CAL
    I do not think turbo of any kind is maintenance free nor found in the realm of "reliable"
    Just my opinion.
  8. Xanatos
    Xanatos Village Idiot VIP
    Florida
    I had a B20z2 with a true cold air intake, 4-2-1 headers and 2.25" exhaust in a '98 RS half gutted and it was a lot of fun for being a super budget build.
  9. dilbeckskate
    Kennesaw Ga
    IMO a turbo setup done properly with quality parts is super reliable and pretty fairly maintenance free esp on anything under 10 psi
  10. Novishok
    Novishok New Member
    puerto rico
    i'm doing some cosmetics rn like the back lights, the wheel and the some interior. also i will repaint the valve cover because its disgusting add a filter etc
  11. Novishok
    Novishok New Member
    puerto rico
    was planning staying all motor idk about the v-tec part yet tbh
  12. CAFROG
    NOR-CAL
    Put a header, intake piping with filter, and 2.5" full exhaust. Decent coil overs and camber kits. It'll be a fun car to drive.
  13. Novishok
    Novishok New Member
    puerto rico
    what about some nitrous? you guys ever had a fancy with it?
  14. Matts96HB
    Matts96HB . Moderator VIP
    Oh yeah, because power is measured in pressure!
    I would take the money you'd put into a nitrous setup and go forced induction. You'll empty bottles faster than you think.
    E_SolSi likes this.
  15. Novishok
    Novishok New Member
    puerto rico
    seems fair any good brands? and should i go vtec or non vtec if i go turbo
  16. dilbeckskate
    Kennesaw Ga
    If your swap is healthy just stay non vtec, you have a large assortment of good cams for non vtec
  17. Novishok
    Novishok New Member
    puerto rico
    ok which rods do y'all recommend? also pistons?
  18. Matts96HB
    CP or JE pistons with Eagle rods are both solid combinations.
  19. Novishok
    Novishok New Member
    puerto rico
    think ill get a walbro 255 also and rc550 injectors
  20. dilbeckskate
    Kennesaw Ga
    id do stock bottom end on low boost and a small turbo (more torque faster and peaks at low rpm) for all out budget, aftermarket pistons and rods etc are nice but then you get into block notching etc , you can literally throw a small turbo on it on stock long block assembly with injectors and a tune and a fuel pump and make 300+ reliable
