Need D series help FAST!!!
Discussion in 'Civic and del Sol - EG and EK' started by welfare, Feb 9, 2007.
  1. welfare
    welfare Ancient Member
    New York
    my brother blew his d16y7 but wants to keep the vtec head, we have 2 different engines that we could use the blocks from, one is a crx hf engine (don't know the engine code but think its d15b6) and the other is a d15b8 (CX) engine. Which one of these would be easier to put the y7 head on? I know we had alot of problems putting an a6 head on a zc because the holes for the head bolts didn't line up, but what about these engines?? Compression ratio and power gain is not an issue here, its just a daily driver, also will the oil pan work on these engines??
    Basically are all the D series engines compatable like the B series are??
  2. juicedz
    juicedz Member
    edgewood, md
    check out D-series.org. Sorry I dont know the answer.
  3. custompainter
    custompainter drive it like U stole it
    central CT
    i dont know all that much but if you put a d16 head on a d15 motor your going to have a weak ass motor if you not turbo'ing it if anything you want the head to be from a lower end civic like a d16 head on a d17 block now that will make some power but going the other way lowers your compression and you'll loss a mass amount of power by doing it your best bet would be go buy a d16 from a junk yard there a dime a dozen you should be able to pick one up 150 to 300 hundred bucks
    o yeah and a d16y7 is NOT a vtec ~ sorry to bust your bubble if thats what you have
  4. welfare
    New York
    for those who are confused, I just talked to my bro. its a y7 block with a z6 head and it is turbo. Im just going to tear it all apart and see what fits. Its just for a couple months until his other engine is done. Thanks anyway!
  5. custompainter
    central CT
    all d- series will work with d - series same block same head just different internals
