Hi! I need aid on a supercharger project - mainly the ECU issues I have. Is it possible to burn a chip which is "universal" or "as universal as possible" for boosting the B16A, if I use a spesific injector/fuel pump setup? Referring to my thread in the "Forced Induction"-section for further info about the project. Thanks! /Boomboxx
as universal as possible = a basemap you should be able to find something close... but unless you have means of monitoring your air:fuel i wouldn't go beating on it with just a basemap...
This sound promising. Where do I find these basemaps? Can someone here make them for me if I specify the injectors and fuel pump? Hmmm. If so, I'm almost in goal, aren't I? I plan on using a wideband O2 and just measure the output (eg. if it's around 2,5V I'm happy), but I must read more on this. Maybe it isn't even possible. /Boomboxx
if your b16 is stock, your best bet without tuning is to go to Hondata - Honda ECU Modification and Enhancement it's expensive, but they have tuned maps for the jackson charger on the old s200 series
Well, I went there, but didn't find much. I'm a little blind, maybe... But anyway, I'll nag a little more! What kind of ECU do I have, exactly? I found somewhere on the net which had an overview of the different ones, but now I've lost it... Sorry for me posting in two threads, I'm a little inpatient, I'm afraid... Also, I'm not that sure which thread everything belongs in. You may delete one if you want to
we are probably that place (check the reference section) that had the ecu list. as pissedoffsol said, get hondata s200, it has maps for the jrsc on a stock b16.
