need ecu?
Discussion in 'HYBRID -> ED-EF / DA' started by opie23, Nov 3, 2004.
  1. opie23
    opie23 Opie
    Howell,MI
    i have a 91 crx dx with a b16a motor swap. i have looked unbeleiveably hard to find a way to delete or bypass the speed limiter or governer. i cant find any thing. should i get a new ecu a hondata or what. need it to be cheap! around $250 to $300. please help
    sorry if there are more threads about this but im desperate
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    You could rechip your ECU. You can get stock chips that have the speed govenor removed on ebay for like $10.
  3. projekteg
    projekteg Senior Member
    what ecu are you running?
  4. brian11to1
    brian11to1 Senior Member
    For the B16 you should propably have either the OBD0 PR3 or PW0... other wise I dunno... those ECU's work best with that engine.
  5. projekteg
    or he could have converted to obd1 or be running a pm6 or pr4 with a vtec controller, etc. we need more info. on your set up to help you.
  6. brian11to1
  7. Citizen_Insane
    Minneapolis
    Why do you need to exceed 120mph? I've gone almost 130 with my stock pw0 ecu....
  8. projekteg
    by the sounds of it, i believe he may be running a pm6 or something with a vtec controller.
