need engine rebuild kit
Discussion in 'Integra' started by asianauto, Dec 10, 2009.
  1. asianauto
    asianauto New Member
    i have been a mechanic for a while now, i don't know much about internal specs on my 1990 integra ls. its b18 can i put b16 pistons on my rods to get more comp.? and will a crank out of a 99 fit mine. with more comp. should keep the same injecters or go bigger/smaller. and were should i get my rebuild kit.
  2. Matts96HB
    Matts96HB . Moderator VIP
    The stock bore on the B18a1 and B16 are the same. So feasibly, yes I believe you could. But there are a few problems that I could see arising:
    1) if you're rebuilding the engine, it's probably got a lot of miles on it. A simple hone might not be enough to clean up the cylinder walls, you might be forced to bore it over the stock bore, rendering the stock pistons (and the B16's) useless.
    2) Wrist pins for the B16 pistons may be slightly different than the B18's. I'm not too sure because I have never done this exact build.
    Higher compression does not necessarily mean you will need bigger injectors. Have the car tuned after the build and see where that puts you.
    Are you talking about a crank out of a 99 Integra LS? If your engine is a B18A1, then yes it will.
    I'm almost positive the 90 Integra LS came with a B18A1, but it could have been a ZC. If it's a ZC, then no you can't use b16 pistons or the crank out of the 99. You have a completely different engine if that is the case.
  3. BrutalB83
    Rochester Hills, MI
    I believe there's an article in the reference section that discusses this very subject (high-compression LS build using B16 pistons). As I recall, it made about 150 wheel horses. Check it out for more info...
