NEED ENGINE SWAP HELP
Discussion in 'HYBRID -> BA-BB /CA-CD' started by REDRUM JOKER, Oct 29, 2005.
  1. REDRUM JOKER
    REDRUM JOKER Junior Member
    I have a 95 accord,5spd with a F22A-OBD1-non vtec in it,I swapped a F22B-OBD2-vtec out of a 96 accord back into it. Im using the stock OBD1 harness and a OBD1 POA ecu. I know i have to run wires from the motor to the ecu for the vtec but i dont know where to run what! The other problem is the distributors are different and I need to how to wire the new one to the old harness!!! Iv tryd gettin help from everywhere and everyone I can think of so any help would be greatly appreciated!!!
  2. reikoshea
    Dallas, TX
    you got to do a little more than that. there are an a lot more sensor's on an OBD2 engine. Check our tech articles on "how to wire vtec"
    if you havent read it yet. before posting, search and check the references.
  3. reikoshea
    Dallas, TX
    You asked for wiring a how to on OBD1 => OBD2 Distributor.
    http://www.hondaswap.com/forums/index.php?showtopic=62088
    check that out. Ive never done it, but im sure that if you wire it backwards it should work. Its best to ask questions on your forums. Its a good chance that more than one person will have your problem.
  4. tab
    tab Super Moderator
    Aberdeen, Washington State
    an easier solution would be to sell that 96 motor, and buy a 95 motor.
    They're only about 300 or so bucks.
  5. reikoshea
    Dallas, TX
    heh, way to think tabbay!
  6. REDRUM JOKER
    The motor im puttin in it is built...it has JE 11.5:1 pistons,the heads been done,gots a header,adj. cam gear & less than 15,000 miles on it!!!
  7. tab
    tab Super Moderator
    I would check into converting the motor to OBD 1. Use your stock harness, a 95 F22B distributor and injectors. That is, if they swap. I haven't done it, but that would be the easiest if the parts match up. That way you could stay OBD1 without an incredible amount of wiring.
    Plan B would be a custom harness for the motor. Plan C would be figuring out the wiring yourself, which can be done with time and patience.
