Need good Exhaust
Discussion in 'General Tech and Maintenance' started by Circuit, Oct 30, 2003.
  1. Circuit
    Circuit Member
    MA, USA
    My stock muffler just fell off, so I think it's time to get a good performance exhaust. I want one that is street legal and that will give me a good hp while still being street legal. Right now I have a B18B engine and am putting a turbo on in a couple of months. Right now I'm looking at the greddy evo exhaust which is suppost to give the best power to noise, but I don't know if that will be the best choice. Help :worthy:
  2. sportlinecrx
    sportlinecrx Banned
    ive heard the greddy evo on a newer prelude and it sounds awesome. very close to a V8 sound.
  3. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    apexi world sport exhaust.
  4. Circuit
    Circuit Member
    MA, USA
    why apexi world sport? :unsure:
    I was reading up on exhausts and apperantly you NEED a 3" exhaust if you're going to turbo. I don't know if this is true though if I get the greddy turbo because it's smaller then other turbos so it would be CARB legal... None the less... sound level is a big issue, I don't want a headache when I drive around. :lol: Anyone know if I really need a 3" exhaust for the greddy turbo or if the greddy evo exhaust would be good enough?
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    thermal for 3"
    apex WS for NA
  6. Circuit
    Circuit Member
    MA, USA
    Exhaust | Noise level | Flow capacity
    Chambered (OEM) | low | low
    Chambered (aftermarket) | low | med
    Straight-through (larger muffler) | med | high
    Straight-through (N1) | high | high
    Twin-pass | low | high
    Apperantly the best option for low noise level and high flow capacity would be the Twin-pass design and down from there the straight-through design (larger muffler).
    as far as the pipe size is concerned, the 3" would be a good size if I do forced induction that reaches over 275whp, which it will after I'm done with it.
    so from that, I know I need a Twin-pass exhaust with 3" pipe... now to find such a creature! :peace:
  7. btleier
    btleier Member
    For a turbo application the bigger the exhaust the better..... within reason. You definitely wouldn't wan tto go any smaller then 2.5", but I would go with 3".
  8. SolLess16
    SolLess16 Senior Member
    also consider a muffler shop doin custom piping - might save some $
  9. CRX_B16B
    CRX_B16B Senior Member
  10. b16ahatch
    b16ahatch Senior Member
    def get the thermal 3 inch i had the apexi n1 on my hatch and made 285whp and when i put the thermal 3 inch on i made 331whp. just goes to show you how much the size of the exhaust helps on turbo applications
  11. illicon2003
    illicon2003 Member
    I heard you can run a turbo with an apex N1..any truth? oops didn't see above post
  12. Cashizslick
    THERMAL CLASSIC 3inch TURBO SYSTEM!!
