need help 89 teg
89tegzc
Just bought blacktop zc i have a 89 integra ls will d series tranny work. or is this projecteven worth the trouble
not quite sure which ZC you are referring to by "blacktop"... they all had black valve covers
however if you are referring to the DOHC ZC then yes it will work just fine... it is essentially the same as the D16A1 that came in your Integra
thanks for the reply but some told me that there was another zc motor that came with a brown valve cover. but heres another questioon for ya my half shaft doesnt line up niether does my rear motor/tranny mount i got bolts in the mount and the tranny the holes dont line up to the block
