need help 92 civic
Discussion in 'HYBRID -> EG-EK / DC' started by hondaplayer, Dec 17, 2006.
  1. hondaplayer
    hondaplayer Junior Member
    need help here is the problem....I replaced main relay, fuel pump and have checked all fuses and ignition system.
    fuel pump doesn't rotate unless I bypass the main relay. I'm not sure what else
    it can be. Do you have any ideas I may have not checked yet? I think all I have
    to check now is the pressure sensor.
  2. loyloy
    loyloy sun^works
    Houston, Tx
    are you getting check engine light and oil light when you turn your key on? i'm having same problems. it USED to be the ground on my thermostat housing that caused that problem for me in past motors. you might want to check that.
