hey, i just did this conversion on my EJ1 coupe...
i bought the entire trailing arm assembly with the e-brake cables off of craigslist. you can get any setup off of a 94-01 integra because it's the same as the eg's...
you are going to need:
trailing arms complete with the rotor setup and maybe new pads
new stainless steel brake lines if it did not have any
e-brake cables (preferably the ones that it came with)
new bushings if they are shot
brake fluid/lots of towels
flair wrenches/vice-grips
extra suspension bolts in case there is some that are seized
*optional* 4040 proportioning valve from a civic or integra (2 in 4 out)
*optional* 15/16" or 1" master cylinder/brake booster setup
this was actually a pretty big pain in the ass for me, mostly with swapping out the prop valve. prepare for some very stubborn fittings, i'm still trying to figure out the whole bb/mc combo i need.
hope some of this helps,
Cheers
