Need Help A.S.A.P. 90 DA
Discussion in 'Integra' started by salvadorrivas13, Apr 28, 2008.
  1. salvadorrivas13
    salvadorrivas13 New Member
    San Jose CA
    Sup guys, i need every one to confirm! Im going to install my 99-00 Civic Si Hydrolic B16 Tranny in my 90 Integra. And i want to know if i can use my Stock 90 Integra Tranny mount, and my stock starter, and the reverse switch? The reason why im asking again, is cuz i only had one person answer my question when there was 100+ that looked at my posting and i only got one reply. Thanx by the way 92civicb18b1. So if you done this before let me know. I got the Cable to Hydro actuator. But i dont have money or time to buy the Hasport Tranny mount! So, can i use my Stock tranny mount and starter and back up censor? Thnx^_^
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    Check to see if the starter bolt up on the cable trans, if it does, then it should work. I don't see why the reverse switch shouldn't work, worse comes to worse, you have to use the one that came with it and just wire it up to an OBD0 plug.
    And as I told you in the other thread, I'm pretty sure you can use your stock trans mount.
  3. salvadorrivas13
    San Jose CA
    Thnx again Bro, do you meen if my starter fits the hydro?
  4. 92civicb18b1
  5. salvadorrivas13
    San Jose CA
    ok ill see right now, um i was reading some articles about this and i read that im not going to use the front tranny mount any more since the Hydro is diferent. and they say that it moves hella crazy that the engine hits the hood! have you ever heard that before?
  6. 92civicb18b1
    I don't see how a lower tranny mount can move enough to hit the hood.
  7. efhondakid
    Akron-Canton, Ohio
    Yes the cable and hydro mounts are diffrent, but the starter and reverse switch will work. You will also have to swap out the electric VSS for the cable one since the speedo on yor car is operated by a cable not a wire.
  8. salvadorrivas13
    San Jose CA
    Thats wat i said, i think those guys are exsatuaring. cuz when my front mount broke it wasent moving like they said. so yea. im with you on this one Bro....;)
  9. salvadorrivas13
    San Jose CA
    yea i know the mounts are different, but do you agree with 92civicb18b1 that i could use my 90DA tranny mount? Thanx
  10. 90DATeggy
    90DATeggy The Pussi Snatcher
    FL
    yea u should i got a 00 gsr tranny in my DA i dont see why u should have a problem
  11. salvadorrivas13
    San Jose CA
    i should wat? my friend ^_^ use my stock mount.?
    1 person likes this.
