street_racer_271
adrenaline is my high
I'm in the process of gutting my interior. I'm wondering if its a bad idea to take out that thick black material that’s on the interior side of the fire wall. Its annoying as hell working behind it, and I’m wondering if anyone else has done it and how. Also is it necessary to remove the oem interior paint on the floor before adding a new coat. It will be flat black. Also, one more, for having a half gutted interior, should I leave headliner in, or out? The front will have full interior excluding the rug, and visors if i decide not to do headliner. Also there is a 6 point roll cage that will be installed soon. It’s the one that goes across the door, not over. One last thing, how do you take out all your SRS pieces. I have a stubborn plug right above the interior fuse box, is there a trick to it? Thanks in advance for any help or advice you can give me.
