Need Help after Engine swap???? ECU HELP???
Discussion in 'ECU's, Electronics, and Tuning' started by crosses, Sep 8, 2010.
  1. crosses
    crosses New Member
    Due to reasons beyond my control I had to get a new engine, it runs ok enough however the ECU thats on it is not the right one so minor conversion had to be done. I have a 98 civic sedan AT that had a D15 non v-tec engine and now it's a D15B v-tec. Now I did some research, the ecu that normally comes with a D15 is a P28 and what I need for the D15B is a P2j. Now if I get the new ecu I know i'll need a corresponding wire looms, now how the hell will the connections go? Also It has come to my understanding that even after doing a mirracle ecu installation my car still will fall short of expectations bcuz the ecu is a bit lazy on the v-tech so i'd need a v-tec controller compatible with a 3 stage v-tec system.
    NEED HELP REAL BAD:eek::eek::eek:
