need help asap
adam91ef
ok so i just swaped my d-series engine in my eg8 and i have an ek block on a ob1 head and so my ek block has the crank shaft sensor but i dont need it on ob1 if im running on a ob1 ecu but my engine is not starting for shitt i have a lx ek block on a vtec head and my shit is not starting i checked for spark set timing correctly checked if my injectors were working properly and still nothing can it be the timing on the rotor
This is the lounge, retard. Did you not see the note that said "no tech posts in the lounge" in capital letters? Go post it in the appropriate tech forum and maybe you'll get a response...
EDIT: Never mind, somebody moved it for you...
