Torque all of the bolts for one cam starting with the top center bolt in between pistons 2 and 3. Torque to 22 ft. lbs then go to the bolt below it. Then go to the next 2 to the right starting with the top, then bottom, then go to the right. The cam seal caps on the sides only get torqued to about 10 ft. lbs i believe. It would sort of look like this.
(13)(09)(5)(1)(3)(7)(11)
(14)(10)(6)(2)(4)(8)(12) Intake Cam side
(14)(10)(6)(2)(4)(8)(12) Exhaust Cam side
A good idea would be to go pick up a Haynes manual for the 94+ teg, Del-Sol and Civic Si. Its a good investement and has all this info within.
Chris
