Need help: B16A2 + emanage + Skunk2 cams
Discussion in 'ECU's, Electronics, and Tuning' started by BallyVTI, May 28, 2005.
  1. BallyVTI
    BallyVTI Junior Member
    Dear All,
    Just installed Skunk2 Stage 2 cams (swapped my ITR cams), have an emanage unit tuned for ITR cams, didnt touch that (yet, not sure what to set) and now I can feel a serious lag in power just after the VTEC point up until 6800. Then everything runs fine. WTF? If running up a hill and shifting from redline, the RPM wont even stagger upward. It stays at ~6000.
    Thanks,
    B.
  2. BallyVTI
    Maybe I should raise the vtec xover point?
    B.
  3. formby
    formby learning in progress
    go to a dyno but it sounds like that could be the problem
  4. BallyVTI
    formby,
    thanks, at least that I can check myself (VTEC point).
    Dyno shops are few and far between in this part of East Europe :(
    Its a lot of DIY.
    B.
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Where are you?
  6. BallyVTI
    Hungary, mostly :)
    B.
  7. xj0hnx
    C.C.TX.
    There's a guy in Budapest, don't know how close it is, he builds turbo MR2's and Celicas, he may be able to help you out, if you like I can try to find his info.
  8. BallyVTI
    I would be most grateful!
    Thank You!
    B.
  9. BallyVTI
    Thank You!
    B.
  10. xj0hnx
    C.C.TX.
  11. BallyVTI
    Thanks a million!
    Will try so!
    All the best,
    B.
  12. BallyVTI
    Its official: THAT was the problem.
    Needed to adjust VTEC Xover point to 6750... and voila.
    No more hesitation.
    Thanks everyone!
    B.
  13. BallyVTI
    BTW, is it 100% safe to have such a high crossover point?
    B.
  14. BallyVTI
    So I dynoed the car. Had a good 6 hours worth of dynoing/tuning.
    I am running RICH AS HELL (9.9:1) at vtec from 5500-6800 RPMs.
    I have NO clue of what to do.
    Suggestions?
    Thanks,
    B.
  15. xj0hnx
    C.C.TX.
    Don't you have a piggyback on the ECU? Lower it till you get right.
  16. BallyVTI
    For some reason GReddy doesnt alter the fuel map below 0 and the airflow adjustment map doesnt have any effect :(
    B.
  17. smooth_criminal
    smooth_criminal Senior Member
    what injectors are you running? it can't be stock if your in 9's that really rich.
  18. BallyVTI
    Stock. Honest.
    B.
  19. BallyVTI
    Just a quick update.
    Problem solved: I sold everything and now am bone stock.
    Not the worst thing in the world, mind you :)
    B.
