Need Help B18c Into A 92 Hatch
Discussion in 'HYBRID -> EG-EK / DC' started by supermonkeyboy, Jan 21, 2003.
  1. supermonkeyboy
    supermonkeyboy Junior Member
    i got a great deal on a 98 usdm gsr motor with tranny axles ecu, and shift linkage. i have a 92 honda civic hatchback cx. what exactly do i need to make the swap possible. im picking the motor up this week, and trying to put it on so i can drive finally... so do i need new motor mounts? different motor mounts? does the fact that the 98 gsr motor is a obd2? thanks for your help :(
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    you will need mounts, shift linkage, and some sort of wiring harness for that OBD2 motor, talk to the guys at locashracing.com they make a harness just tell them what you have and they will tell you what you need. the only problem is that they are kind of pricey.
    So good luck.
