Need help converting wiring harness
Discussion in 'General Tech and Maintenance' started by OnesickCrx, Feb 14, 2004.
  1. OnesickCrx
    OnesickCrx Member
    I got a 89 Crx Si with 92 jdm sohc zc vtec the vtec(this motor is exactly like D16z6 motors in US) is disengage because the wiring harness that I am currently using is the old one that went with the d16 motor. I got a p28 chiped skunk 2 ecu and would like to use that but I need help converting the wiring harness because it does't fit anybody know how I would go about this their any easy way to do this I looked at the pins from the P28 which is diffrent and the one I am using is the 89 crx si ecu currently using their not the same. Any help would be appriciated
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    Get a Helms manual. Start from one side and work to the other. Lengthen wires as needed. Make solid connections. You don't want to second guess yourself.
    I don't know if you have an OBD issue or not.
    Bump
  3. OnesickCrx
    OnesickCrx Member
    what I got is OBO I think since the old wiring harness came off 1989 crx
    The ECU I got is OBD1 I am guessing since its 1992. Their any ecu converters out their that are already made I dont trust myself doing that.
