Need Help - Distrubutor Coil
Discussion in 'ECU's, Electronics, and Tuning' started by 22crazy, Mar 1, 2003.
  1. 22crazy
    22crazy Senior Member
    whats up, i have a stock 1996 CX hatch back....im putting in a tach expect i dunno where the distributor coil is...the diagram says its connected from a wire from the distributor...expect theres only four wires which are for the spark plugs....can anyone tell me where i can find the distributor coil....thanx.
  2. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    pull your cap off and there will be a thingy with a little metal... thing on the end of it off to the side (not in the middle of it) that is your coil
  3. 22crazy
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    maybe you should consider taking your car to the shop to have this done...
