Need HELP,,,, don't start
Discussion in 'Civic and del Sol - EG and EK' started by Tein, Aug 12, 2009.
  1. Tein
    Tein So much with a little D
    Kissimmee, FL
    I need help with my D16Y8 project I am trying to start the car after 4 years. Everything under the hood its new includind a tranny swap... When I try to start the engine it makes only a sound like TAK TAK and there is no sign of starting at all. I was thinking a bad starter.</p>
  2. DESPAIN
    flower mound TX
    check to see if you have a bad ground. rep if it heps.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    does the motor actually turn over ?
  4. Tein
    Kissimmee, FL
    <p>I am at work right now, but as soon I get home I will check on that... The motor its suppose to turn, I mean it got it from the machine shop after getting new pistons rods and a block guard...</p>
  5. benson1121
    benson1121 New Member
    Atlanta
    is it a quick ticking? if so its probably the starter. when swaping my old motors out my buddy accadentaly pulled out one of the wires going into the starter. it made that sound when i tried to start it i ended up duct taping the wire into the starter (i know ghetto fab) but now im asking around for quotes to drop my lsd b18c1 (i cant do it myself im in afghanistan)
  6. AHHVTEC
    Alabama
    but does the motor turn over
  7. Tein
    Kissimmee, FL
    It take about a second to do exactly TAK, TAK... I will defenetly going to check the grounds and if can't find anything missing then I will look for another starter... Before bought another starter how can I know for sure that my die?
  8. DAallday
    DAallday New Member
    Are you sure your battery isn't dead? You can test the starter yourself by using this site. Or some auto stores may test it for you.
  9. rkwoos12
    rkwoos12 New Member
    Kentucky
    do you hear the motor turn over or when you turn the start key and crank it over are the power steering belts and stuff like that turning?? if there turning then i dont think its your starter cause its cranking your engine.
  10. AHHVTEC
    Alabama
  11. rkwoos12
    rkwoos12 New Member
    Kentucky
    man we really cant help you out unless you can tell us weather or not your motor is cranking over, or you can go spend 100 bucks or w/e and buy a starter and it may not be your problem.
  12. Tein
    Kissimmee, FL
    Ok guys sorry for the delay but I just came from work, the battery is new, the starter is used and right now I am going to try to turn the crank... and when i was trying to start the car nothing it moves at all just the sound of TAK, TAK...
    So let me try to move the crank and I will came back to give you the update...
    And thanks a lot to all of you...
  13. Tein
    Kissimmee, FL
    Ok guys, the crank it moves... its not like butter when I turn it but its not stuck either...
  14. Tein
    Kissimmee, FL
    tomorrow I will be able to spend some quality time on the car and try to made this happend... After so much time i am dying to hear this car sound...
  15. runner253
    runner253 New Member
    did u get it started
  16. Tein
    Kissimmee, FL
    I believed the dizzy is not getting power... I will go over the wiring of the 5 speed swap but I am almost sure that I made something wrong... What should I need to look for to. Made sure that the dizzy is getting power? What wires I need to put together when doing the 5 speed swap?
  17. Tein
    Kissimmee, FL
    I took the starter to autozone and is not good... I purchase a rebuilt unit online and was delivered today... I am on my way home to try it...
  18. Tein
    Kissimmee, FL
    The starter and the Batery are new and still not able to start the car?
