turbowagon92
whats up, i have 92 honda accord w/built h22a w/t3/t4 turbo.the computer is a p28 w/crome pro base map.when i start my car and rpms raise to 2000rpm on tach. when temperature needle raises to operating temp the idle stays at 2000 rpm,when i give it gas rpm goes up and down from 1500 rpm to 2500 rpm.then it smooths out and idles at 2000rpm.this just started about 3 days ago.my car usually idles at 1100- 1300 rpm.what possibly could be causing this problem?i don't know maybe the map sensor or tps sensor,could it be my ecu itself?my car has not been boostin right neither.my car is set at 10lbs by wastegate spring no boost contoller but yet only about 4 lbs of boost.that is another issue that is bothering me.
