I have a 91 accord 5 spd. The motor is shot, and i found a 94 accord f22 out of an automatic car. Will the swap work out? Anything i will have to change?
You would be swapping an obd0 motor for an obd1 so you will have to do some wiring not 100% sure but you could probably use the same mounts,axles,tranny,but probably have to get a new harness and possibly ecu.
