my friends car is having clutch issues. when the pedal is pressed the gears grind and do not go in. when you get it into gear the car goes with the clutch pressed in. the slave cylinder is moving about an inch or so. just as much as my car. he has a 94 ex bone stock. the clutch doesnt slip or anything. what would cause this? i was thinking maybe the pressure plate fingers are messed up.
