eastkoastkustumz
Member
I have a 94 del sol that I just put a jdm b16a into with the hydro gsr tranny and axle stubs along with the p30 ecu. I recently took the valve cover off and saw that the head was bored out bigger to fit bigger springs into it. Then i took out the cams and all I can notice on them is at the ends of each of them they have this ring that says :K S Ars ( I think its says ars, its very small and hard to tell) B 7 . and then there is a few other numbers. But I have no idea what ths means. I have yet to take the head off because I figure that I should find out about the cams first. Any help would def. be appreciated, thanks for looking
Fred
SEVENONESIX
Fred
SEVENONESIX
