Need Help For Volt Meter Gauge!
ovcrash
Hi,
I would like to know where do i connect the wire of my Volt Gauge Meter that i got from AcAutotechnic? I have a red wire and a black wire for the volt gauge.
And i have a Red wire and a Black wire for the lights in the volt gauge.
So where and how do i connect all of this?
Thanks alot for your help.
BTW: i have a 1997 Civic Hatchback.
i'd assume you'd tap into anything with 12 volts when the key is on, and then ground the black .
get a voltmeter and go to the fuse box and there should be some leads that are keyon ignition off
