Need Help Identyfying Engine Type
DSM TUNER
Well i jus bought a 89' 5 speed CRX for 350$ runs very good.... needs a new mirror and windsield...but anyway...i need help identfiying the engine type i didnt really have much time to grab the number off the block ....but it said 16 valve and i only seen one cam....im jus wondering if this was stock for any of the years it was made...or did some one put it in? were the crx si's a sohc 16 Valve..thanx fo helpin out
umm doesn't it take about 30 sec to a min just to check an engine block code.
1. open hood
2. wipe the flat surface between exhaust manifold & transaxle
3. bend down a bit
4. apply light, glasses (if required)
5. read engine code
6. write down code if your memory isn't that good
7. remove light and close hood
I think that would take a full min.
But really... The only 100% for sure way you know which engine you have in your car is to read the engine block code. 89 CRX.. I think there was two/three models. A coupe (DX/HF???) and a Si model. The Si has the 1.6L. Please correct me if I'm wrong.
Chris
90 Civic HB ZC 5spd :sleep:
Canada
crx engines:
HF = D15B6
DX = D15B2
SI = D16Z6
note: if you dont know which model you have because it doesnt say SI or HF on the back of the car, then you probably have a DX (they had no designation on the back).
