street_racer_271
adrenaline is my high
Hey I'm new, my name is Abe, I have a 93 civic with a GSR engine, I have the Autometer Pro-Comp Ultra Lite Water and Oil Temp gauges. For the Oil temp, I heard that I could just replace the sensor with the oil plug, but thats not what I want to do since I'm getting a magnetic drain plug, So I was thinking of getting the Moroso Oil pan (unless someone suggests something better) and drill a hole in it an weld the adaptor into in an put in the sensor. But what do I do with the water temp? Do I need to get a hose fitting, cut my rad hose, put the fitting between the two pieces and put the sensor in there? or is there an easier way. Any help will be appreciated. Thanks in advance.
