Need Help Just Bought Eg 93 Lsi Hatch
Discussion in 'Civic and del Sol - EG and EK' started by g.h.racing@hotmail.com, Sep 27, 2006.
  1. g.h.racing@hotmail.com
    g.h.racing@hotmail.com New Member
    Its Me Again Need Good Advice For Engine Swap Willing To Spend 2 To2.5 G O Before I Forget I Live In Spain Malaga
  2. OneSlowEK
    OneSlowEK New Member
    Well, in all actual, the best swap i think IMO for the EG hatch would be a kseries swap, but that is out of the realm of your 2.5g, so i would actually look into getting a GSR swap, or at least a ls/vtec or b20/vtec. But it all varies on what you want to do, boost or all motor.
  3. g.h.racing@hotmail.com
  4. eg6sir
  5. OneSlowEK
    Drop in an LS its the cheapest motor for what your trying to do. I think a full motor swap can be had for around 1g. After that take the other 1g and try and get a turbo kit, or build your own. LS are more fun on boost IMO anyways LS/V is a lil tooo high compression for me and a lil less reliable. After the swap, just redo the internals with pistons and rods on a low compression and you will have fun with a daily driver in a light ass car.
    parts for turbo if you were building it yourself should be easy. But also remember that tuning is the key to a long lasting motor. A kit will be more expensive in any area of 1500-2500 dollars, building one will cost u under 1k without tuning with tunign will be a bit more.
