need help modding my single cam vtec
r.l.brown
i have a d15b single cam vtec motor swapped in my 94 ex coupe with 40,000 miles on it. i have intake exhaust and headers. what else should i do. i am trying to do all i can for a single cam. please help me and thanks.
You could swap a larger displacment block in like the d16a6 block. I'm not sure about with the d15 but with the d16 you can get better rods and pistons. If you plan on staying all motor the extra displacment will deffinatly help. Another thing you could do after swaping the block is get some higher compression pistons.
Some cheap bolt ons would be a B series throttle body, d16y8 intake, larger cam with upgraded springs/retainers etc. Although I would suggest you save up and put in a turbo or save for a B series swap.
hey thats great cuz im definetly squeezing every penny. thanks for the info and maybe i'll do that. thanks again
