id avoid that 83 prelude at ALL COSTS. unless you plan on fabbing your own mounts there's not a lot you're going to be able to do with it.
For 10G id stay in the following ranges:
88-2000 Civic
88-2001 Integra
92-2001 Prelude
90-97 Accord
ANY Del Sol
All of those are easily swappable and the older ones can be had at a very nice price.
For 10Gs, i personally would go for a 92-95 civic (hatch preferred, but they're usually a bit more expensive). Id swap an LS (B18B) engine add a B16 head, and since you said you want to do forced induction, reinforce the bottom end with some eagle rods. Pick up a turbo (If it were me, i'd probably go towards something like a GT28 or a GT30)
You can get intercoolers pretty cheap if you look in the right places (IE, not summit or jegs). You can have a muffler shop fab your charge piping. Pick up a new manifold of course. If you've ever done FI, you should know where you're going from there.
If you pick the civic, a lot of people like to upgrade to the half size radiator for better clearance.
From there its tuning. You can alter the stock d-series wire harness to work with the LS/VTEC (the engine i described above) you'd only need to add 3-4 wires. Use a P28 ecu (check ebay for a virgin or slotted one...DO NOT buy a pre-chipped one). Take the car to pretty much any tuning shop and they'll be able to get you at least a base map for your turbo build, the better ones will want $$$ for dyno time and tuning.
grab an eg shell, pickup an LS swap and a b16 head. at a minimum upgrade the con rods. piece together a turbo setup and have it tuned.
