wassup everyone, i have 2000 civic cx and just dropped in a '95 b18c and now i am having wiring problems. (i think) it already fired up once and ran for about 30 min left for a couple hours and fired it up again. left overnight, came back the next morning now wont fire at all engine turns but no spark from plugs now i have a couple of question about the wiring if every thing was hooked correctly how do you hook up iacv how do you hook up iab what happens to ckf sensor, and secondary 02 sensor where does blue wire from dizzy go which vss do i use. cx or b18c where do charcoal canister lines go this is an 0bd2b-obd1 swap so i used a harness jumper and using the cx harness this is my first engine swap so any would be greatly appreciated
If you are getting a CEL for the IAC, clean it out, reset the ecu, reinstall it, and it should go away. Mine did after I cleaned it. The IAB is wired to a17, just bypass the jumper harness and hardwire it to the ecu. use the b18c VSS. Not sure on the blue wire. One is a vent, One connects to the big port on the top of the throttle body, and I think the small line on the top of the canister goes to the evap purge.
