Need Help On Distributor Wiring
B16RacerN2NR
Working Hard
VIP
I just swapped my obd-1 distributor for an obd-0 distributor because the obd-1 will not work with my pr3 ecu...i was told to do this since i have an obd-0 chassis with an obd-1 motor running off an obd-0 ecu...everyone follow that?? :D now my question is do i get first gen plugs (the wire harness side) and put it on that way so the distributor plugs in? or is there another way to do it? if i need the harness side plug...do parts stores sell it or do i got to go chop it off another motor? any help would be good here...thanks
if you put an obd1 motor in an obd0 chassis, and are running an obd0 ecu, the pr3, that is correct.
you will need the obd 1 plug to connect to the dizzy, alternator, and injector harness. splice those 3 things from the obd1 harness onto the obd0 harness. you will need a helms for both car and motor so you can get the wire colors right.
stores don't sell that kind of stuff.... you will need to score a harness.
well damn doesn't that suck to be me...i'ma try to find one at the junk yard
