Need Help On Gsr Swap
wtc7676
Member
I am in the middle of swapping an OBD 1 GSR in my 5th gen. civic coupe. Which front supports(motor and transmission) am I supposed to be using?(GSR or are the ones out of my civic supposed to work). Also the hood does not want to close(motor clearence), any suggestions?
Also, any other things that people have run in to that I should know about?
Thanks,
Will
ALSO...how many mounts should I be using? I count five?(correct?) 3 main motor mounts and 2 front supports.
you shouldnt have hood clearance issues... what mounts are you using?
If you have all the gsr mounts i would go ahead and use all them
