need help on head
Discussion in 'Engine Building' started by integracer9447, Apr 6, 2004.
  1. integracer9447
    integracer9447 Junior Member
    what parts do i need if i want to change my camshafts on my 96 integra ls? do i have to buy new valves, springs, etc? any info would really be a good help. than :worthy: ks
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i'm looking for a little help myself, but we're talking about diffrent things... :lol:
    no, just take old cams out and put new ones in, take it to a shop if you don't know this, one mess up and your head will be fucked with bent valves smashed into it...
    good luck
  3. Import Builders
    Import Builders Senior Member
    LA, California
    ok buddy, I got answers.
    You can use the same valvetrain, if your new cams are similar in lift and your not revving past where you did before.
    The reason people get new springs, is for larger cams and to rev higher. For this, you need stiffer springs.
    And there you have it.
    Jeff
