need help on (sohc zc)!!!!!!!
Discussion in 'HYBRID -> ED-EF / DA' started by cavrx, Aug 20, 2003.
  1. cavrx
    cavrx Senior Member
    ok i got the car to finally idle normal. now if you hit the gas it bogs out. has anyone had this problem? if so whats the solution? for those who dont know i am working on a 1991 crx dx with a sohc zc. any help would be appreciated!!!
  2. ohmstable
    ohmstable Senior Member
    Toronto, Canada
    I think it may be an ignition problem. Make sure plugs, wires, dist cap and rotor are ok. I had an issue like that and it turned out to be a cracked dist cap.
  3. cavrx
    cavrx Senior Member
    i'll try it and see what happens
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
    did you switch the wires on the TPS? - the DPFI TPS turns in the opposite direction from the MPFI - you should have a green wire on the harness connected to the yellow on the TPS, red connected to red, and yellow on harness connected to green on TPS
