Need Help On Swapping H22a Into 94 Integra
Discussion in 'Integra' started by boosted_H22A_teggy, May 18, 2016.
  1. boosted_H22A_teggy
    boosted_H22A_teggy New Member
    i have a 1994 integra with a locked engine i been told it would be cheaper if i just buy a new engine so i found a cheap h22a but i wanna know if the h22a mounts and harness wiring will fit my car if not so i can get the right ones?????
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Your username is boosted h22 teggy and have no early idea whats needed or info on the swap.... facepalm ..... you need engine/trans, axles, and swap mounts , or a h2b conversion and use your bseries trans, which is probably auto even
