Need Help On Tire Sizing
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Capt. Orygun, Jan 7, 2003.
  1. Capt. Orygun
    Capt. Orygun Win the Day
    Oregon
    hey,
    I want to buy tires for my new rotas (thx ALLJDM), there 15"X6.5. I want the widest tire acceptable by the wheel. I also want to keep the same ride height. I tried to determine the size myself but realized the number that determines ride height in tire sizing is actually the ratio. Anyway here my stock tire numbers 195X55. Thanks in advance...
  2. 2 litre EG
    2 litre EG Senior Member
    so cali
    195 will fit and maybe even 205... but im not 100% sure so this size should work
    205/55R15
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    The 205 will fit. I run 205/50/15s on 94 GSR wheels.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    205/50/15 will be your best match- 205/55 is going to be a little too tall. 215/50/15 would be ideal, but I don't think anyone makes that size...
  5. E_SolSi
  6. phunky.buddha
  7. smithby
    smithby Junior Member
    I have Kumho 712's on my 92 Si 205/50/15, $62.00 each. Do you need a all season tire or just a tire for the warm weather climates?
  8. La_Pieuvre
    La_Pieuvre Senior Member
    Dallas, TX
    I have Kumhos 712's sized 205/50-15 on my 15" Slipstrams and they fit perfectly. When I bought the tires at Discount Tire they installed the wrong size (205/55-15) and they were too tall and rubbed against the inside of the wheel well when turning. They had just made a mistake when looking at my order. ;)
    205/50-15 is probably the best size to get if you want the widest for that wheel.
    I used the Tire size Calculator found in the "Reference" section
    --> TIRE SIZE CALCULATOR <--
  9. Prowler
    Prowler Super Moderator
    B MT
    I would NOT use 215s on a 15x6. 205s are already wide enough for my 16x7's.
  10. E_SolSi
    :werd:
    if you have too wide of a tire you will get a lot of roll over and your cornering will suck ass
    you want your sidewall to sit:
    like this: |___|
    not like this: /___\ or this \___/
    either of the botom two will provide shitty handling
    damn my art work kicks ass :D
  11. silentSCREAM
    silentSCREAM Junior Member
    The widest you should go is 205's. 215's will balloon on the side and fold over under hard cornering. 205/50/15s is the way to go. I highly recommend Toyo Proxes T1S.
