Need Help Picking Right Turbo...
Discussion in 'Forced Induction' started by speedprowagon, Mar 31, 2003.
  1. speedprowagon
    speedprowagon Junior Member
    hello tomorrow i will be ordering a new turbo kit for my car which is a 92 civic hatch with a gsr motor . the turbo i want is a turbonetics t3\t4e ballbearing. what trim and a/r should i order?? right now the motor is stock so i would like to run 6-9 lbs, but in the near future with the block sleeved and a hondata and new rods and pistons i would like to run 16+ lbs and achieve 380 whp+. im spending the money now and getting the ballbearing so i would like help picking a good trim and a\r to achieve the above . thanks albie :blink:
    i was looking into a 50 trim 60\63 a\r but im not sure>>>>
  2. pissedoffsol
  3. speedprowagon
    thanks for the reply pissedoffsol.. i was thinking about going with the t3 60-1 but the turbo kit manufacturer really only deals with the t3 t4. .. i want to pick a t3 t4 that will not boost out on the top end and that will not lag so much to make the boost ... what do you suggest pissedoff i should get as far as trim and ar? i think them 48s spool to fast but i think the 57 might lag too much. i need some help.... albie
