Need Help to get home from work - please help - clutch pedal issue
This problem started yesterday out of the blue and has been annoying the crap out of me each time I go to start driving my car. (96 dx stick with 150,xxx mi.) After letting it sit for a period of time like over night or while at work when I go to start it I am having problems getting it to shift into 1st or reverse while the car is started.
I can shift with no issue when the car is off. As soon as I push the clutch pedal it feels very soft and when the engine is started the car starts to move in which ever gear I have it. If I try to shift into neutral I can't so I turn my car off and try again. After I get moving and run through a couple of shift cycles I can feel the pedal has more pressure and I can shift fine for the rest of the drive.
I do not think it is tranny or clutch related but more of a clutch pedal problem - gears 2-5 work fine and once I am on the road 1st and reverse work fine as well.
So here is my question is there a way to adjust the tension on the clutch pedal to help the clutch disengage sooner? Is there like a master/slave cylinder that I can check?
I looked under the hood and all I could find were two caps located by the drivers side rear that both had "brake fluid" on the caps. Am I missing something if so please point me in the right direction. I have a shop at school and can do the work myself if somebody could just explain what I am looking for or what I need to do. All I need is a point in the right direction to get me started.
Any help would be appreciated as I want to limp this car along as long as possible to avoid a car payment.
Thanks in advance.
Thanks in advance.
