Well you should not put any lube between machined surfaces like between the valve seats and the cylinder head. The layer of lubricant acts as a bushing affecting the clearance. It may also, in time, cause the seats to come loose. Regular old engine oil works just fine on things like the seals. Lubriplate is good also.
