hello all.
i am trying to replace a timing belt on my 91 crx d15 motor i have loosed the timing belt removed the alternator belt, upper timing cover. i am now stuck on the lower crankshaft pulley bolt i have jammed up the cam gear with a bar and i crank away at the bolt but all i get is a poping noise when it turns i think i am moving the whole pulley even with the cam jammed up.. i have put it into fifth gear like many had suggested in other posts.. i do not have access to an impact wrench or air compressor to use with one. i think i am just jumping teeth on the timing belt. i also tired jamming the lower pulley but looks like i am starting to damage the hole... please if anyone has any other ideas please help. o by the way i am rotating it counter clock-wise.. here is a video link of what is going on...
thanks again
Video of crankshaft pully bolt - Photobucket - Video and Image Hosting
thanks again
