Need Help suggestions
Discussion in 'Prelude' started by eMans92lude, Jun 18, 2007.
  1. eMans92lude
    eMans92lude New Member
    hi I need some advice I just got this hooked up 92 Honda Prelude Si(Hooked up Body) for a good price......you know the 2.3....How can I make it a vtec.... Ive heard a lot about the LS swap....and some people told me to drop a h22 head on it.....and also its an automatic and I want to make it a 5speed........What should i do First?...or any suggestions??/
  2. Ic3
    Ic3 Newb Engine Swapper
    Ottawa Ont
    Hey eMans92lude!
    I don't know that much about preludes but I will try my best.
    I like the current engine in your bay is a H23a1. Yes if you replace the top with an H22 Vtec head it will be vtec aslong as you hook everything up right. I am pertty sure the head bolts up with the h23a1 but I can't be certain. To make the car 5 speed just get a 5 speed tranny for that engine and bolt it where the automatic one was.
    Check your engine code then read a little bit on match up heads for it with vtec and you should be okay. Hope this helps
    Ic3
  3. eMans92lude
    Well my engine is completly stock......what do you have for good price i need everything??
  4. Ic3
    Ottawa Ont
    Well what do you want to do exactly? If you want v Tec you can pick up the v tec head for that block cheap anywhere... If you want the 5speed tranny, get a H series tranny. To be safe just get one off your car but 5 speed. There is alot of pull it junk yards around and if you have a friend that knows what hes doing, you guys should be able to pull whatever you want from there in a few hours and leave real happy.
    Ic3
