need help to convert from auto to manual on a 90 honda hatch?
Discussion in 'Civic and CRX - EF' started by jcizzle, Oct 16, 2006.
  1. jcizzle
    jcizzle New Member
    i droped in a manual d15 usdm motor and tranny. need help with the wiring part of it. use my auto engine harness or manual engine harness? do i need to wire up the clutch pedal or something. please i need help..... honda ef9 fo shooooo....:(
  2. ef8
    ef8 Junior Member
    U can use your auto harness,it will just have a couple plugs u will not use.
  3. SavageDreams
    SavageDreams Savage Reins Supreme
    Taft,Ca,93268
    I personally would get as much stuff that goes with a manual because the auto ecu will have a different mapping then the manual I beleive but dont quote me look into it more and yes u need the pedals and everything from amanual
  4. gettocrx
    gettocrx Member
    Honolulu, HI
    remember to wire in the reverse switch so your reverse light will work!:D
    just plug in the 5speed ecu, no conversions needed! some ef's dont have a clutch switch, but if it does your can bypass it using a button or a toggle (kill switch) for your starter! other then that.... Have fun putting in the pedal assembly!
  5. ef8
    ef8 Junior Member
    I didnt mean he could use the auto ecu,i just meant that he does not have to get a 5spd engine harness,there will just be a couple extra plugs near the tranny that will not be used.As for the conversion Rywire - Automatic To Manual Conversion
  6. SavageDreams
    Taft,Ca,93268
    oh thats just what I thought, thats my bad.
  7. xxji3lazexx
    xxji3lazexx 1SIKEK4
    RHODE ISLAND
    You can use ur auto ecu if u wanna be cheap it wont run right but itl run i did the same shit in my hatch i took out a blown d15 90 civic -to a d15b7(92-95),the harness from the auto matic harness is fine but ir ur runnin a mpfi throttle bottle gotta get a SI wire harness.if u decide to use your auto harness there's going to be a plug on the rear of your block under your throttle alittle more to the left of the middle lol..i also did the auto to manual swapp also and it came outtt pefect make sure u dontt do any shortcuts..pedal's wern't bad as i thought it would be,drop ur sterring column.. dont try and squeez it in there it could bend...ur welcome..
  8. 94civicturbo
    94civicturbo New Member
    Liberty, IN
    once again... CHECK THE DATES!!!! :locked2: :locked2: :locked2: :locked2: :locked2: need i say more? :locked2: :locked2: :locked2: :locked2:
