need help tuning euro b16 crx
IcelandCRXvtec
hi
my name is Marteinn
i live in reykjavik, Iceland.
i´m just the biggest honda fan in iceland ;)
i need help tuning my
honda crx 1991 b16a1 euro version 150hp
only picture i have
http://www.live2cruize.com/Samkomur/2004/1...4/160904_19.jpg
the mods i got is cold air intake in the bumper,
2,5 inch exhaust no cat and
vafc but it is just normal settings.
my best time on this car is 14,565
and i want to go lower.
i have toda racing flywheel at home and
toda racing high power profile pistons 81.50.
i´m thinking about skunk2 stage2 cams
and what other parts i need
here in iceland few people beleave in honda
and at the only race track in iceland there are
90% american cars racing.
sorry for my spelling :)
crx@visir.is
Install your pistons and cams, but make sure you have upgraded valve springs and retainers to match those high profile Skunk2 cams. You don't want to float a valve at high rpms. If you have access to a dyno, see if you can negotiate an hour or two of the owner's time so that you can tune your car. Your VAFC is good enough to adjust your fueling to get the most out of your engine after the bump in compression and the extra breathing from the cams. Make sure you're wired into a wideband O2 sensor while you're on the dyno- this way you can make sure you never go too lean and damage your engine.
If you have enough money to throw around, you might want to send your head to someone here in the US (or a Honda specialist around you if there is one) for a port and polish job. You pick up quite a bit of flow in the top end with a proper port in the head- sometimes as much as 20hp or more, depending on how the rest of your engine is set up. I would also look into using a custom ECU system like Uberdata or Ghettodyne for your B16. Both would allow you to tune your ECU with more precise fuel maps than the VAFC, and you can play with your ignition timing maps as well. The ignition timing maps are where you really pick up quite a bit of power.
